Announcements
Help with making this form in to a body
Hello I want to make this form to a body so i can 3d print it. I have tried to use thicken but it doesn't work. Am i forced to remake the body ore can i do something else?
Here is a public link: https://a360.co/2OZ2fV1
jeff_strater
there are 5 bodies here.  Which one do you want to make into a solid?
picking one, there are areas of high curvature that will make a BRep surface offset likely fail:
You can try a Thicken in Edit Form mode, instead - that is more likely to succeed.  When I tried it with one of the bodies, the result had intersecting faces that would have to be untangled before converting to BRep, but that is not all that difficult.
There are areas of high curvature
Jeff Strater
Engineering Director
