Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Joint Conflicts
4 REPLIES 4
740 Views, 4 Replies
Joint Conflicts
So I'm still new to Fusion and I'm trying to model a hexapod, loosely following a tutorial at the moment and in the last bit of rigging I'm running into joint conflict errors (literally on the last three connections.)
Not sure if it makes a difference but all the arms are referencing another file and I've tried tinkering with the joint limits within that file still to no avail. Help much appreciated!
4 REPLIES 4
innovatenate
Can you share the Fusion Design?
Nathan Chandler
Principal Specialist
in reply to: innovatenate
http://a360.co/2kTyJmN
Is this alright?
innovatenate
Can you try this and see if it helps?
This one degree of freedom may help. See attached example for more detail (hint: upload command in the data panel).
Nathan Chandler
You sir are a king amongst men, thank you so much!!
