So I'm still new to Fusion and I'm trying to model a hexapod, loosely following a tutorial at the moment and in the last bit of rigging I'm running into joint conflict errors (literally on the last three connections.)
Not sure if it makes a difference but all the arms are referencing another file and I've tried tinkering with the joint limits within that file still to no avail. Help much appreciated!
Solved by innovatenate. Go to Solution.
Can you try this and see if it helps?
This one degree of freedom may help. See attached example for more detail (hint: upload command in the data panel).
