Fusion Support
Issue with new sheet metal flat pattern?
4 REPLIES 4
javipk
1956 Views, 4 Replies
Hi there,
Before the recent change in the way 'create flat pattern' works, I used to make a sheet metal part flat, create some features (cut slots along the bend lines, to laser cut and make it bendable by hand, sort of like a living hinge in plywood) and then bend back again to see the result. Now features created in the 'flat pattern workspace' won't reflect back to the sheet metal part once exiting it. Is this a bug or how do I create features in the  'flat pattern workspace' that will reflect back? Chamfers or fillets don't work either
thanks for the constant improvements!
4 REPLIES 4
karina.harper
in reply to: javipk
Hi @javipk
I think you're thinking of unfold/refold rather than editing the flat pattern.
Also, fillets and chamfers seem to be working fine for me. Can you give me an example file where you're seeing this happen?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
javipk
in reply to: karina.harper
Hi Karina,
yes that works, thanks!
Yes I was using 'create flat pattern', thinking the 'unfold/refold' feature had been eliminated and integrated into 'create flat pattern', didn't see it still existed.
So I imagine 'create flat pattern' is mostly a tool to create a DXF when the design of the sheet metal part is finished?
karina.harper
in reply to: javipk
@javipk
Yes, I think you have it right. You can also make changes in the flat that don't update back to the folded model which is handy for some people.
Cheers!
Karina
Karina Harper
Hi, I had the same problem. It might be good to update official tutorials. All examples (at least those I've found) use old GUI. Even Karina's gif has buttons that are now at a completely diferent location.
