Issue with installing fusion 360
abinessa
abinessa
Hi guys, I am trying to install fusion 360 and i get that unable to write certain files and quit explorer exe i cannot find it on the task manager please can someone helping me in that please a video is easy. Please see the attachement the error i am getting right now. thanks.
Replies (12)
RajkumarIlanchelian
@abinessa Most times the simplest solution to this is restart your machine and try again. If that does not work, there should be a link the error to collect logs. Please collect and post here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
abinessa
It is working now but I got another issue when I try to save the file as DWG, It says fail please see the attachement. Any solution to that? Thanks.
RajkumarIlanchelian
@abinessa Is this the only file that is failing or pretty much any export is failing? Would you be able to share this design?
Autodesk Fusion
Join Fusion Insider
abinessa
here it is in the attachment but i also found that my fusion says not connecting to internet is that also an issue to convert the file to DWG?
RajkumarIlanchelian
@abinessa You certainly need the network for translations but first we have to solve why you are not on the network.
Easy and first thing to get out of the way is to reset your router to see if that fixes the issue. If not we go collect logs (Go to your Help - support and diagnostics - Fusion service utility - gather system info and attach the Fusiondiagnosticslogs zip file here).
Autodesk Fusion
Join Fusion Insider
abinessa
I get these above and long time not connecting????
abinessa
not clear can u do a video or pics thanks
abinessa
I get this when i try to connect online
RajkumarIlanchelian
@abinessa Are you able to flip that switch back to online?
Autodesk Fusion
Join Fusion Insider
abinessa
It is working online but converting the file to DWG still not working????
RajkumarIlanchelian
@abinessa Is that the only export not working? Also, what entitlement you have? personal , education, commercial ?
Autodesk Fusion
Join Fusion Insider
abinessa
With STL file as well fail? I have an education one
