Announcements
White dots on drawing causing (one or more passes were discarded due to linking constraints error)
it will create paths for everything but the circle with the white dots. and when i run simulation it completely skips that piece. there's another part that doesn't have the white dots and it cuts it no problem
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jhackney1972
Do you need further help in attaching your model?  I think could be a quick solution if I had your file.
jasonzebedee
hi i am not sure how i am unable to get in here to chat, this is not in regards to the white dot issue. i am having linking restaint issues again suddenly. i am trying to cut a harley davidson logo. it will cut out the little dash between harley and davidson yet it is skipping over whole letters, or it is starting the cuts not where i want them. fusion is really starting to irritate me.   is there an easy to use program for plasma cutting?
jasonzebedee
here is the file in question
