Hello everyone,
Can someone help me solve this issue. Ever since the previous update my models show incorrectly in Fusion 360.
What used to be color, texture, or detailed is now pitch black. This happens ONLY in the MacOS version, when I open the files in a Windows machine (see right side of the picture) it shows up correctly.
It does not seem to be related to the model having been created in a different machine since it visualizes correctly in any Windows machine I have tried other than my own.
Thanks!
Solved by carlosacostaZQZK4. Go to Solution.
Solved by RajkumarIlanchelian. Go to Solution.
@carlosacostaZQZK4 Is your macOS Sonoma? We are aware of certain appearance issues with Sonoma and are working with Apple to resolve them.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@carlosacostaZQZK4 We are releasing an update likely sometime next week that should address most of these issues but we have a few more that we are working with Apple to address.
Autodesk Fusion
Join Fusion Insider
@carlosacostaZQZK4 If you can pass on the model and I can take a snapshot of how it looks with na internal build and out back here.
Autodesk Fusion
Join Fusion Insider
@carlosacostaZQZK4 Apologies for the late reply. Attached is a picture of what the latest internal build is showing. This version will be updated or scheduled to be update early next week.
Autodesk Fusion
Join Fusion Insider
Thank you Raj!, it looks as it should on the right. I'll be eagerly waiting for the upcoming version.
Carlos
