Hi!
I noticed it in a recent update.
Is the default value of the default modeling direction the Z up?
神原Θ友徳(かんばらΘとものり)Tomonori Kanbara -JAPAN-
この投稿が参考になりましたら、「いいね」を押してください。
この投稿で問題を解決できましたら、「解決策として承認」ボタンを押してください。
Solved by jeff_strater. Go to Solution.
I think the default for new users has been changed to Z-up, but your preference should be maintained if you have a preference of Y-up
Hi! @jeff_strater
Thank you for your answer.
I understand.
In Japan, Fusion 360 training books are prevalent, because it is written as default value Y up, it causes users to become confused.
Many users are using Yup.
Thank you,
