I want to design an item which I modify to multiple variants.
So I crated a component "base" and copied into a component "variant a" with "paste" instead of "paste new". That meant though that changes I made in "variant a" were also applied to "base". But I don't want that bi-directional behavior. I want to be able to make changes to the base item while I already created variants.
Is it possible that only changes on the parent (base) are applied to the child (variant a)?
Here a simplified exmaple. If you check the attached file that the "base" component doesnt look like it should.
This is my base item
This is variant a
