Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
installation problem
1 REPLY 1
lukas.hrmn
154 Views, 1 Reply
hey everyone,
i got a problem with the installation of the program. Its installating himself on part "C" of the hard disk.
The point is, that this one is full. Full with important data i cant delete.
So i want to install it on part "E".
You guys have an idea how that works?!
1 REPLY 1
jhackney1972
in reply to: lukas.hrmn
Fusion 360 is configured to install to C: drive by default.  Since it is a web deployed application this fact cannot be changed.  If C: drive is also your Windows operating drive, which is probably is, you will have to copy your important files to another drive in order to make room.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
