Fusion Support
ribs feature in multibody part does not work
6 REPLIES 6
415 Views, 6 Replies
6 REPLIES 6
MoshiurRashid
Thank you for posting. It would be good if you demonstrate the issue with more descriptiona,  provide us photos and also your f3d file.
(File> Export> f3d)
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
in reply to: MoshiurRashid
I may be using this feature for what it was not intended. My part is made of many bodies including the ribs. Perhaps a different approach is required. Oddly the geometry i am attempting to create via the rib feature are called ribs in the physical apparatus (boat) hence the expectations of this feature:)
MoshiurRashid
Hi
Why dont you create it as another body and "combine" it? Please have a try.
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
the design objective is to have a multibody part
ribs feature in Onshape works elegantly! normal or parallel to sketch plane, multibody, merge or not merge
TheCADWhisperer
File>Export and Attach *.f3d file here.
