Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Insert Logo in Titleblock Template
4 REPLIES 4
atcunninghamS5TPH
248 Views, 4 Replies
I don't seem to have the same edit title block options that other users have.  When I am in my drawing template, when I click into the titleblock to edit it, (screenshot of state below) I don't see how to insert an image (logo) into the bottom left space of the title block.  If I go up to the "insert image" via menu on the top tool bar, I pop out of editing the titleblock and it just inserts the image onto the page.
Oddly enough, even when saved with an image inserted into the drawing template, when I try to make a drawing and select this template, the image also doesn't appear in my new drawing from design.
Screenshot below of template modifications (inserted image in drawing field, clicked into insert image directly out of edit titleblock state (screenshot above), edited titleblock text, and inserted text
Saved template, went to generate new drawing, and all inserted images and text disappear.
4 REPLIES 4
Hi @atcunninghamS5TPH
This is down to selection. If you click on the title block, then right click it, you will see "Edit the Title Block", you should then be able to edit it and add in the image that you require.
Thanks, @ClintBrown3D  but I don't see that option when I right click...
btw, I'm on a mac...
Mac and Windows selection is the same 🙂
First left-click on the block, it will turn blue, then right click on it and choose "Edit Title Block"
ClintBrown3D
in reply to: ClintBrown3D
Hey @atcunninghamS5TPH
I probably should have mentioned that the easiest way to edit the title block is from the browser:
