Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
In correct tools in post
1 REPLY 1
jerrybentley
243 Views, 1 Reply
Again,  I am off the rails on this.   A milling program  3 axis.  When I post ,my feature will post with the correct tool and the proper tool change is ordered.  After that another incorrect tool will be listed without a tool change being ordered.  I go thru the code and erase all these incorrect tools this takes time.  I have tried different post and its the same.  Again  What am I failing to see.  This is a sample
1 REPLY 1
hello @jerrybentley
Can you give us more information please ?
What is the controler on the machine?
How the machine is layed out?
Tool changer can come in 2 differents configurations.
Either a swinging arm, or an umbrella.
Umbrella tool changer doesn't use tool preparation, swinging arm does.
It's possible that a property in the post allow to switch this behavious on /off.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
