Again, I am off the rails on this. A milling program 3 axis. When I post ,my feature will post with the correct tool and the proper tool change is ordered. After that another incorrect tool will be listed without a tool change being ordered. I go thru the code and erase all these incorrect tools this takes time. I have tried different post and its the same. Again What am I failing to see. This is a sample
Solved by serge.quiblier. Go to Solution.
hello @jerrybentley
Can you give us more information please ?
What is the controler on the machine?
How the machine is layed out?
Tool changer can come in 2 differents configurations.
Either a swinging arm, or an umbrella.
Umbrella tool changer doesn't use tool preparation, swinging arm does.
It's possible that a property in the post allow to switch this behavious on /off.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
