Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Imported STL Mesh Clipping When Zooming In
5 REPLIES 5
jk6208XFV9
321 Views, 5 Replies
Hi, first time posting.
Couldn't see anything that was specific to my problem from searching the forums. Apologies if I've missed it.
I've imported STL meshes to a new project, but anytime I try and zoom in on them, the viewport goes white, like it's clipping. Video attached.
I have no idea how to resolve this, any help would be greatly appreciated.
Thank you!
Labels (6)
5 REPLIES 5
jhackney1972
in reply to: jk6208XFV9
Sounds like a video issue.  Have you tried changing the Fusion Graphic Driver to see if it helps.  The driver chosen should match the standard you video card or adapter uses.  The Preferences are opened by right clicking on your log-in Avatar in the upper right hand corner of the application.
John Hackney, Retired
TrippyLighting
Please select one of them in the browser, right click, and select properties. What dimensions do you see in "Bounding Box"?
jk6208XFV9
in reply to: jhackney1972
I have it set to Auto Select.
jk6208XFV9
in reply to: TrippyLighting
They are quite small values actually...is this the problem?
jk6208XFV9
They were scaled really small in import. 1000 times smaller.
Rescaled and problem is gone, thank you!
