Announcements
I cant install fusion 360 on my macos sonoma 14.5
miquelin
miquelin
I try to install a client version of fusion 360 on my user on macos sonoma 14.5, but it's fail. I got a message that it doesn't have internet connection, but I just download the installer, I have internet connection. When i try to do the install in command line I receive the message:
The application cannot be opened for an unexpected reason, error=Error Domain=RBSRequestErrorDomain Code=5 "Launch failed."
Can anyone help me?
RajkumarIlanchelian
@miquelin Can you please clarify if you cannot install or you cannot launch? the logs shows that you do have the application installed.
WARNING :: Exception in Deploy No need to update. 2.0.19426 installed
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
miquelin
When I run the installer it says that I don't have internet connection, but I have( picture 01).
I try to install with command line, and it works if i do a sudo command (picture 02), but at the finish I got an error saying that it can't launch the app, and the icons of the apps have a stop icon. I resolve this changing the permission of the files, but if Ilauch the Fusion 360.app it hangs ..
If I launch the service utility and test my internet connection is ok, but any other options like redefine or reinstall doesn't works.
I discover that if I install and use the Fusoin 360 begins before the enter my "applid" at the count everything is ok. So this make any kind of incompatibility between Sonoma 14.5 and Fusion 360.
Any kind of help?
RajkumarIlanchelian
@miquelin Thank you for the details. Can you please explain a bit more on this "I discover that if I install and use the Fusoin 360 begins before the enter my "applid" at the count everything is ok."?
Autodesk Fusion
Join Fusion Insider
