I've got a number of components in a file. I'd like to have them all sit naturally on the ground/ground-plane so the renders look more realistic. Is there a function/tool to achieve this?
Thanks in advance.
Jason
Solved by jhackney1972. Go to Solution.
Any model where the components sit on the Origin plane are on the ground plane. In my example, an assembly, I will move all the components to a point on the X-Y plane. If you do not have an assembly and want each component to be independently moved to the X-Y plane, then you will have to repeat the process for each component. Take a look at my Screencast. As I pointed out, watch out for Grounded components.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
