Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to sit All components on the ground plane?
2 REPLIES 2
jasonu3w
1454 Views, 2 Replies
I've got a number of components in a file. I'd like to have them all sit naturally on the ground/ground-plane so the renders look more realistic. Is there a function/tool to achieve this?
Thanks in advance.
Jason
2 REPLIES 2
jhackney1972
in reply to: jasonu3w
Any model where the components sit on the Origin plane are on the ground plane.  In my example, an assembly, I will move all the components to a point on the X-Y plane.  If you do not have an assembly and want each component to be independently moved to the X-Y plane, then you will have to repeat the process for each component.  Take a look at my Screencast.  As I pointed out, watch out for Grounded components.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jasonu3w
in reply to: jhackney1972
Legend! Thanks for the help. Much appreciated.
