Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to Refine Sweep Surface Geometry - HELP
1 REPLY 1
pjk33
113 Views, 1 Reply
I'm working on a design with very low tolerances. I've posted an image below. Is there a way to stitch these surfaces?
Notice how on the right side the sweep is smooth and then it segments. These subtle angles are a problem when use SLA printing due to it being able to capture the detail.  I assume this has to do with the splines that are used to make this sweep possible, but the rail I am using has no voids to my knowledge. The portion that I've highlighted is good, so why can't Fusion replicate this smooth surface throughout the entire sweep?
Since I'm somewhat of a beginner with surface modeling, maybe there might be a tool or setting that I've overlooked?
Labels (6)
1 REPLY 1
TrippyLighting
in reply to: pjk33
Please share your model. I somehow doubt that the curvature continuous borders between patches can be seen in a 3D print.
Technology Administrators
