I am a newcomer to Autodesk and I have created several sketches that I do not need right now . I am trying to clean up this excess tries so that can go on learning about this system. How to delete these sketches. Thanks Tom
Solved by jeff_strater. Go to Solution.
Solved by g-andresen. Go to Solution.
Solved by isthicks. Go to Solution.
Solved by TheCADWhisperer. Go to Solution.
rightclick sketch (browser or timeline) > delete
However, this only makes sense if this sketch is not used for extrusions.
günther
I think that I did just what you said but the sketch stays there, the design I created is gone but I want to get rid of the whole sketch
I think that I did what you suggested but the design is gone but the sketch is still there. I have 10 sketches created with just junk on them and I want to get rid of them and start over.
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
@isthicks - as @g-andresen said: share the design here. Also a video of what you are attempting. Deleting a sketch is pretty straightforward, and should work as described here.
