Hi Everyone,
I remember that there was a way to make a video of what one was doing in Fusion 360. One purpose of making such a video is to explain a problem so that you can ask about it on a forum. How do we make such a video? I don't remember how to do it.
Thanks in advance.
Vincent
Solved by JeromeBriot. Go to Solution.
use Screencast.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Hi @Anonymous
Thanks for posting! It sounds like you are looking for Autodesk Screencast.
I hope this helps! Please let me know if you have any questions.
Hi Jerome,
Yes, that is the video program I was thinking of. I have now installed it. Thank you.
Vincent
Hi Paul,
Yes, that is the program I needed. Thank you very much.
Vincent Gillespie
