In my preferences, under General, and at Pan, Zoom, Orbit Shortcuts, I have my setting set to Tinkercad as I prefer the easy orbit shortcut. But the marking menu shortcut doesn't seem to work anymore. Due to the fact that the easy orbit takes up the right click, the marking menu is not there anymore. Does anyone know how to access both the Tinkercad orbit shortcut and marking menu?
Solved by jeff_strater. Go to Solution.
hold down the Shift key, and use the right mouse button - that should bring up the marking menu in TinkerCAD mode
Is there any way to set a custom shortcut for the marking menu? or any other way to access the marking menu? I am so close to getting my Fusion360 mouse controls to work the same as my Rhino3D mouse controls now that I have a cadmouse, but I would really like to have the marking menu as the click of the mouse wheel or at least as an item in the 3d Connexion radial menu.
