Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Help needed!
5 REPLIES 5
javiguajardolever
257 Views, 5 Replies
Help needed!
How do a I make a cut through an object using a pipe? I'm trying to make a siphon and every time a cut through to make it hollow using the profile of the pipe i cut through the pipe.
5 REPLIES 5
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
I see in your screen capture a very full Timeline...a lot of effort there....But all Unsaved? Get into the habit...the very First thing you do....Name your Project. Can you share your Fusion file?
yeah, bad habits i know... It's saved now :). I've uploaded the file, if any of you can help me it would be amazing.
Unless I am missing something,
Make another Pipe at inside diameter (9.6 mm).
Might help...
Thank you so much, first time using the tool.
