Fusion Support
Help! Make ellipse solid
4 REPLIES 4
660 Views, 4 Replies
Hi, sorry for the noob question. I've drawn an ellipse and then extruded it however the object is hollow and not solid. How can I make it a solid object like the cylinder beneath it. Any help would be great.
4 REPLIES 4
pawel.potyrala
Hi @Anonymous,
welcome to Fusion 360 Community Forum!
If the elipse sketch was a closed one, you should be able to create a solid with the Design -> SOLID -> Create -> Extrude command (Model -> Create -> Extrude in the old UI).
You can also use the Design -> SURFACE -> Create -> Patch feature to create closing faces and Stitch the shape afterwards. I recorded a short screencast with the other workflow here: https://autode.sk/2KFvLgT (it should be available in a few minutes).
Let me know if that helps. Thanks!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
in reply to: pawel.potyrala
Hmmm, I think I didn't finish the sketch of the ellipse. I have done that now, attempted to extrude the ellipse but now it just cuts a hole in the lower cylinder instead of creating a new object. Am I selecting the wrong thing?
OK, no problem, it was defaulting to cut when I entered the extrude length. I changed this to new body and I have success! Thanks for the help.
pawel.potyrala
Hi @Anonymous,
thanks for getting back to me! Exactly - you can choose "New Body", "Join", "Cut" or "New Component" options for these operations.
I encourage you to go through the following tutorials for Fusion 360: Fusion 360 Adoption Portal. If you are stuck on a workflow, the following related Community Forum should be the best way to go: Fusion 360 Design, Validate and Document.
Thanks!
Best regards,
Paweł Potyrała
Technology Administrators
