When I try to start fusion I get an error (text below) and am unable to log in. it indicates an update might resolve the issue but I don't see a way to download and apply an update without being logged on. how do I resolve this? it was supposed to be a busy day.
Solved by RajkumarIlanchelian. Go to Solution.
@javelin_exile Not sure what the error you are referring to is but you can try the below:
1. Launch Fusion and while launching press Ctrl+shift (windows) or cmd+shift(Mac) to launch the Fusion service utility
2. Run the repair Fusion 360 and that should take you to the latest version
If this is not working please add any image snapshot or using the Fusion service utility please collect the system information and post the zip files generated here please?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you I will try this. and here is the error that I forgot to paste.
Date/Time: 2023-02-03 11:47:06 -04:00
Application: Fusion360.exe
Error: C++ EH exception - code e06d7363 (first/second chance not available)
Crashed Module Name: KERNELBASE.dll
Exception Address: 0x00007ffca4b006bc
Exception Code: e06d7363
Exception Flags: 81
Exception Parameters: 19930520, ce6bb0d870, 7ffc9d8f32d0, 7ffc9d890000
This worked but I had to start the utility by another method the ctrl/shift trick didn't work. I selected right-click/ change in the programs list in windows and that made it come up.
