in my model environment the grid keeps disappearing. I check the "layout grid" box, it appears briefly and as soon as I do anything it disappears. it seems to uncheck itself. I've read through related threads and although they are marked as solved there doesn't appear to be solution so I'm starting another thread
Hi @Anonymous,
thanks for posting! I have the following questions regarding the behaviour you observed:
I would also like to ask you to try the following steps:
Let me know if that helps. Thanks!
Best regards,
Hi @Anonymous,
thanks once again for posting! Have you managed to review my suggestions from the post above?
Let me know if you need further help. Thanks!
Best regards,
Thanks for your advise Pawel, I went through all your suggestions apart from checking the graphics card, not quite sure how to do that. It’s a one year old IMac so imagine the graphics card is up to date enough. Unfortunately the grid still keeps disappearing.
Hi @Anonymous,
thanks for the reply! If you have all the latest updates for your iMac, the graphics card should be up-to-date as well.
I have a few additional questions:
Thanks in advance!
While it won't help us track the root of the issue, you may also try to resolve it by running our Fusion 360 Cleaner tool perform a clean uninstall of Fusion 360 and re-install the software afterwards: How to do an automatic clean uninstall for Autodesk Fusion 360.
Best regards,
