Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Geometretric pattern function not available on imported geometry?
2 REPLIES 2
nicolas_meiresonne
119 Views, 2 Replies
Hi all,
I noticed that the Geometric Pattern function is not available/showing when I upload and open a STEP file into Fusion 360. Am I correct to assume that this Geometric Pattern function only works on geometry that is build inside Fusion 360?
I have the product design extension active and I'm able to use it on a simple plane when creating one in Fusion360.
Would be nice if this feature would work on imported geometry as well.
Thanks for your help!
Nicolas
2 REPLIES 2
When importing designs in formats other than f3d, the design history is deactivated by default.
Activate Design History.
günther
Got the issue fixed! Thank you
Technology Administrators
