Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Generative Design Fail to Send - How to Fix
2 REPLIES 2
372 Views, 2 Replies
I have done a few generative designs in the past with no issue. I went ahead and purchased more cloud credits for this study. When I submit the study to start, I get the scheduling cloud solve has successfully started popup in the bottom right of the window. Immediately after, I get a failure to send error. I don't understand why it isn't working. Help would be appreciated. Thank you
Labels (1)
2 REPLIES 2
henderh
Hi @Anonymous,
I'm not able to reproduce this on my end, I suspect it could have been an intermittent issue.
If you continue to see this, please attach the log file (Help pull-down -> Support and Diagnostics -> Diagnostic Log Files). You can attach the zip file here or email it to me directly at hugh.henderson@autodesk.com.
We apologize for the inconvenience this is causing.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Hi there,
I'm facing the same issue. In the logs it says: 20211006T144121 E 2069724 *Generative* Failed schedule cloud solve:Payment Parameters are missing.
I'm on a 7day trail, t evaluate a purchase.
Thank you.
Technology Administrators
