Generative Design Fail to Send - How to Fix
This widget could not be displayed.
I have done a few generative designs in the past with no issue. I went ahead and purchased more cloud credits for this study. When I submit the study to start, I get the scheduling cloud solve has successfully started popup in the bottom right of the window. Immediately after, I get a failure to send error. I don't understand why it isn't working. Help would be appreciated. Thank you
henderh
Hi @Anonymous,
I'm not able to reproduce this on my end, I suspect it could have been an intermittent issue.
If you continue to see this, please attach the log file (Help pull-down -> Support and Diagnostics -> Diagnostic Log Files). You can attach the zip file here or email it to me directly at hugh.henderson@autodesk.com.
We apologize for the inconvenience this is causing.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Hi there,
I'm facing the same issue. In the logs it says: 20211006T144121 E 2069724 *Generative* Failed schedule cloud solve:Payment Parameters are missing.
I'm on a 7day trail, t evaluate a purchase.
Thank you.
