Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
generative Design export fails
1 REPLY 1
s202087
172 Views, 1 Reply
Hi there,
I have started a generative study and would like to export the result as a construction. But that doesn't work. I always have these error codes:
Fehler: {"id":"995581c5-588e-4d54-ac70-81e10ed42a30","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"68342ffc-ba04-4f67-a4a2-2b533e2eb8c9","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"c35af5f2-5dc0-4cca-bb7b-c5707d577624","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"af5ab7ae-3dca-4111-9219-254a90e2d11b","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"f34a6ddb-7ba5-4dd5-99b7-142c6ea0bced","code":"INTERNAL","details":"Unknown error"}
The export to a mesh works, however.
What am I doing wrong?
Greats
Tom
Tags (1)
Labels (1)
1 REPLY 1
s202087
in reply to: s202087
Here the f3d file. The generative outcome with the problem is labeled as favorite.
Technology Administrators
