generative Design export fails
s202087
s202087
Hi there,
I have started a generative study and would like to export the result as a construction. But that doesn't work. I always have these error codes:
Fehler: {"id":"995581c5-588e-4d54-ac70-81e10ed42a30","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"68342ffc-ba04-4f67-a4a2-2b533e2eb8c9","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"c35af5f2-5dc0-4cca-bb7b-c5707d577624","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"af5ab7ae-3dca-4111-9219-254a90e2d11b","code":"WORKER_ERR","details":"ASM error no: 58000, API_FAILED, operation unsuccessful (Execute)"}
Fehler: {"id":"f34a6ddb-7ba5-4dd5-99b7-142c6ea0bced","code":"INTERNAL","details":"Unknown error"}
The export to a mesh works, however.
What am I doing wrong?
Greats
Tom
s202087
Here the f3d file. The generative outcome with the problem is labeled as favorite.
