Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
fusion360 failed to translate the step file
7 REPLIES 7
Message 1 of 8
konpanas
1004 Views, 7 Replies
            Is it my files that corrupt or is there something I need to do before I can open these 2 step files?
Thanks in advance
Best,
Konpanas
These files are from Prusa github, I paste link here in case there are problems with my download
https://github.com/prusa3d/Original-Prusa-i3/tree/MK3S/Printed-Parts/STEP
7 REPLIES 7
Message 2 of 8
Hi, Thanks for using Fusion.
I tried to upload the files you shared and I get the error stating "Error: [extruder-body.stp]: Content of the file is corrupted or invalid". It could be a scenario where the file is either corrupted or incorrect.
I tried to open in other software, which also says the file content is invalid.
Can you please try creating the step file again from the source and try uploading it again.
Let us know your valuable inputs.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
Message 3 of 8
HughesTooling
in reply to: konpanas
Don't think you downloaded the files correctly. Try the files in the attached ZIP file.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
Is your problem solved?
Sasi
 Sasikanth Kollipara
LinkedIn
Message 5 of 8
konpanas
Thank you so much, Mark. The file attached works
@AnonymousYes, the problem solved with Mark's files.
Although I have no idea why my download corrupt the files because I still can not "uncorrupt" my downloads even several tries from the Github source, it still gives me error.
Message 6 of 8
HughesTooling
@konpanas  I've never quite figured out downloads from GitHub but what I did was click the file I want then when the text file is listed click on Raw then right click on the text and save as. This seems like a lot of effort, think there should be an easier way but not obvious.
Mark Hughes
Message 7 of 8
Good that the problem is solved now.
Sasi
 Sasikanth Kollipara
LinkedIn
Message 8 of 8
konpanas
in reply to: HughesTooling
@HughesTooling Thank you so much for this method. It all works now!
