I just tested this on my Macbook and it seems to be working okay. Is the image file really large?
Can you try the suggestions in this article?
I'm wondering if you connect to a docking station with an external monitor on occasion.
I hope this helps! Let me know either way.
My offhand guess, without more information, is that the dialog for the canvas file is there, but is where you cannot see it, or is behind Inventor. Can you try the "Reset to Default Layout" command here:
Just by the way, have you ever used an external monitor? Sometimes dialogs can get lost if you have used an external monitor.
Can you post a copy of the DirectX diagnostics from the computer?
What happens if you disconnect all but 1 monitor and then restart Fusion 360?
Here is that file.. havent tried disconnecting monitors..
Everything looks good in the dxdiag. Have you tested disconnecting some of the monitors to see if it helps?
If you haven't yet done so, does restarting the computer help?
There could be a background interference like anti-virus software interfering with the normal operation. You may try temporarily disabling or adding an exception in your A/V software.
Have you installed anything since the program was working and then stopped working? You might look at the install dates in the programs and features in the control panel to see what was installed recently. Those may offer some clues.
I hope this helps!
I have tried disconnect all monitors but one to collect it all in one.. Didn't help.
I did Uninstaller AV the other day.. Macafee had expired so u installed it.. This might have been aroubd the same time. Right now windows defender is running. Tried to turn it of but it was the same.. Added recommended files to whitelist in defender.. Doesn't help..
ok . So we mixed accounts here.. me and my son.
however the screencast is "pendning" as I type..
here is the screencast to download.
I have a WIN10/Ryzen 7 1700/ GTX1060x and the insert canvas functions all do not work. When you click to browse for a file, the directory dialog box simply does not open.
Hope this helps. It happens with all the insert photo file options. May just be a simple UI issue with the WIN10/AMD/GTX pairing.
We reinstalled windows on this PC and installed fusion 360 again and now it works just fine..
