Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion not working properly, unusable!
14 REPLIES 14
Message 1 of 15
et.teljemo
1619 Views, 14 Replies
Hi.
My son was working on the one hour lamp practice and called me telling me he had trouble inserting canvas.
When I tried later there really is a problem.. And not just with this.
But with this as example:
I open the insert canvas tool, select plane and then clicking the load image button.
It doesn't open any explorer and the button turn gray again.
The plane I selected keep on being selected (blue) even after closing the tool.
This problem is everywhere! Can click on some things but most things don't react.
I have tried reinstalling fusion-360 completely with no effect.
What to do?
14 REPLIES 14
Message 2 of 15
innovatenate
in reply to: et.teljemo
I just tested this on my Macbook and it seems to be working okay. Is the image file really large?
Can you try the suggestions in this article?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
I'm wondering if you connect to a docking station with an external monitor on occasion.
I hope this helps! Let me know either way.
Nathan Chandler
Principal Specialist
Message 3 of 15
jeff_strater
My offhand guess, without more information, is that the dialog for the canvas file is there, but is where you cannot see it, or is behind Inventor.  Can you try the "Reset to Default Layout" command here:
Just by the way, have you ever used an external monitor?  Sometimes dialogs can get lost if you have used an external monitor.
Jeff Strater
Engineering Director
Message 4 of 15
et.teljemo
I'll try those things later today thank you.. However I don't have a laptop at all.. So the external monitor issue might not be it?
Also.. The canvas was only one example.. It is like fusion crashes after using a function that doesn't work.. Can't get back.. Need to restart.. Can't select or deselect a plane or surface after trying to use for example canvas..
Message 5 of 15
et.teljemo
Didn't solve it 😭
What is going on???
Message 6 of 15
et.teljemo
He has 3 monitors on his computer.
Could he have done some changes in some settings?. Last time I borrowed his computer to draw fusion worked fine.
Message 7 of 15
innovatenate
Can you post a copy of the DirectX diagnostics from the computer?
  1. Launch %windir%\system32\dxdiag.exe
  2. Select Save All Information
  3. Please reply with the resulting *.TXT file attached
What happens if you disconnect all but 1 monitor and then restart Fusion 360?
Nathan Chandler
Message 8 of 15
et.teljemo
in reply to: innovatenate
Here is that file.. havent tried disconnecting monitors..
Message 9 of 15
innovatenate
Everything looks good in the dxdiag. Have you tested disconnecting some of the monitors to see if it helps?
If you haven't yet done so, does restarting the computer help?
There could be a background interference like anti-virus software interfering with the normal operation.  You may try temporarily disabling or adding an exception in your A/V software.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Con...
Have you installed anything since the program was working and then stopped working? You might look at the install dates in the programs and features in the control panel to see what was installed recently. Those may offer some clues.
I hope this helps!
Nathan Chandler
Message 10 of 15
et.teljemo
I have tried disconnect all monitors but one to collect it all in one.. Didn't help.
I did Uninstaller AV the other day.. Macafee had expired so u installed it.. This might have been aroubd the same time. Right now windows defender is running. Tried to turn it of but it was the same.. Added recommended files to whitelist in defender.. Doesn't help..
Message 11 of 15
et.teljemo
Screencast of the problem.. Should have done this from the beginning..
Message 12 of 15
Message 13 of 15
et.teljemo
ok . So we mixed accounts here.. me and my son.
however the screencast is "pendning" as I type..
here is the screencast to download.
Message 14 of 15
I have a WIN10/Ryzen 7 1700/ GTX1060x and the insert canvas functions all do not work. When you click to browse for a file, the directory dialog box simply does not open.
Hope this helps. It happens with all the insert photo file options. May just be a simple UI issue with the WIN10/AMD/GTX pairing.
Message 15 of 15
We reinstalled windows on this PC and installed fusion 360 again and now it works just fine..
