https://www.mcmaster.com/shell.aspx is yellow
Solved by RajkumarIlanchelian. Go to Solution.
@amahmud3 Can you please do a couple of things?
1. Can you please post log files from this machine that is not going online?
2. Also, if you connect to another network, say a mobile hotspot, is Fusion going online?
3. Can you restart your router as an option to see if that addresses the issue?
Bottom line is that something is preventing Fusion calls and we need to find out which one. Could also be Windows defender firewall. iIf you can turn that off and see if it goes online that will help.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@smaggioli You cannot login or does Fusion go offline after login. The original thread is about cannot go online.
Autodesk Fusion
Join Fusion Insider
@smaggioli
1. Close Fusion
2. Go to C:\Users\(username)\Appdata\Local\Autodesk\DELETE Autodesk Fusion 360
3. Now start Fusion again
Does this help?
Autodesk Fusion
Join Fusion Insider
