Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion not going on-line
6 REPLIES 6
amahmud3
266 Views, 6 Replies
6 REPLIES 6
@amahmud3 Can you please do a couple of things?
1. Can you please post log files from this machine that is not going online?
2. Also, if you connect to another network, say a mobile hotspot, is Fusion going online?
3. Can you restart your router as an option to see if that addresses the issue?
Bottom line is that something is preventing Fusion calls and we need to find out which one. Could also be Windows defender firewall. iIf you can turn that off and see if it goes online that will help.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Salve, ho lo stesso problema. Non riesco ad accedere on-line
@smaggioli You cannot login or does Fusion go offline after login. The original thread is about cannot go online.
Autodesk Fusion
Join Fusion Insider
I cannot go on line with my PC. If tried to make the diagnostic, there an
error : mcmaster.com/shel.aspx
If i try with my mac it works.
@smaggioli
1. Close Fusion
2. Go to C:\Users\(username)\Appdata\Local\Autodesk\DELETE Autodesk Fusion 360
3. Now start Fusion again
Does this help?
Autodesk Fusion
Join Fusion Insider
smaggioli
in reply to: smaggioli
Yes!!! Thank you!!!
