Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion is getting stuck randomly during simple sketch commands
11 REPLIES 11
Message 1 of 12
ID01C2PNH
472 Views, 11 Replies
Fusion is getting stuck during simple sketch commands, during exiting and entering sketches, edit feature command etc.
it gets stuck for minutes and then crashes but sometimes it resumes
i'm attaching a screen recording here you can find the task manager at the end of the video.
It started the past week and i feel like its getting worse now..
Tags (3)
Labels (1)
11 REPLIES 11
Message 2 of 12
CGBenner
in reply to: ID01C2PNH
@ID01C2PNH
Hello and welcome.  Has this problem been all with the same file, or with any Fusion design you work on?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 3 of 12
jeff_strater
please share the this design here.  While adding a line may seem "simple", if the sketch itself is very large, the entire sketch solve time can take a very long time.  Even adding a "simple" line causes the entire sketch to solve.  Most of the time, you can simplify sketches by splitting them into multiple sketches, removing patterns (do the patterns in solid), etc.
Jeff Strater
Engineering Director
Message 4 of 12
ID01C2PNH
in reply to: CGBenner
I'm currently working on two projects both of them are having the issue
Message 5 of 12
ID01C2PNH
in reply to: jeff_strater
both are just 4-5 body assembly nothing complex
Message 6 of 12
ID01C2PNH
This is the sketch that im working on, an dim using an intal i9 laptop with 16 gb ram and nvidia gforce rtx 4gb gpu,
Cant share the whole design its under nda, please let me know how can we resolve this quickly
Thank you
Message 7 of 12
jeff_strater
@ID01C2PNH - can you share just this sketch?  That is, if you copy all the geometry in this sketch, and paste it into a new design, do you also see the slowness?  If so, then can you share just that design here?
Jeff Strater
Message 8 of 12
ID01C2PNH
I saved the sketch as .dxf and opened it in another window, but now all the constraints and dimensioning are lost
but for the sake of testing it i tried giving it some constraints and did some extrusions its not getting stuck now.
as for the previous design files..it had some unwanted components and bodies so i removed everything and kept just 9 bodies and 6 sketches..its still getting stuck frequently
Message 9 of 12
ID01C2PNH
I can send the design to your mail id if it helps solve the problem faster.
Message 10 of 12
jeff_strater
yes, you can send it to me at jeff.strater@autodesk.com.  But, what I was suggesting was not exporting via DXF (which does strip out constraints and dimensions), but this workflow:
  1. open your design
  2. edit the problem sketch
  3. select all the geometry in that sketch (area select)
  4. Copy
  5. Create a new design
  6. create a new sketch
  7. Paste
  8. Exit sketch
  9. Save
export that design as an F3D, and post it here
Jeff Strater
Message 11 of 12
ID01C2PNH
I've send the whole file via mail to  jeff.strater@autodesk.com from saheem@thebluarmor.com
, please check it out and let me know what can be done to rectify this.
also, my fusion ram usage is from 8- 15 GB, is this normal ?
Message 12 of 12
CGBenner
@ID01C2PNH @jeff_strater
Hello!  Circling back here, has this been resolved?
Chris Benner
