Fusion Support
Simulations stucks at 1%
29 REPLIES 29
Message 1 of 30
id00859520
771 Views, 29 Replies
For any simulation you do, even in the case of only a linear load on a bar it remains loaded at 1% and does not advance even if you leave it for a long time.
29 REPLIES 29
Message 2 of 30
henderh
in reply to: id00859520
Hi @id00859520,
Could you attach the log files zip when Job Status is showing 1% progress? (Help > Support and Diagnostics > Diagnostic Log Files).
Thank you,
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 3 of 30
id00859520
in reply to: henderh
here is the file.
Message 4 of 30
henderh
Thank you for attaching the diagnostic files @id00859520.
We've cleared the queue for your account. New solves should be able to process now.
Best regards,
Hugh Henderson
Message 5 of 30
roman_bonilla
Hi, I have the same problem, but for having Educational account can not creat a topic. May you help me please?
Message 6 of 30
henderh
in reply to: roman_bonilla
Hi @roman_bonilla,
We've received that your account is stuck also through the product support channel. We're working on getting this addressed as soon as possible for you.
Best regards,
Hugh Henderson
Message 7 of 30
henderh
Hi @roman_bonilla,
Your queue has been cleared, and you should be able to solve again.
We apologize for the inconvenience.
Hugh Henderson
Message 8 of 30
roman_bonilla
Hi @henderh
Thank you so much for your attention. It works now. I really apreciate it.
Message 9 of 30
albertogutmar
I have the same problem and I can't figure out a way to solve it by myself. Could you help me as well?
Message 10 of 30
henderh
Hi @albertogutmar,
You should be good to go now. Thank you for providing the log files.
Best regards,
Hugh Henderson
Message 11 of 30
jpetty1
I am also having this problem
Message 12 of 30
henderh
Hi @jpetty1,
Could you attach your log files?  (Help pull-down > Support and Diagnostics > Diagnostic Log Files)
That info is needed to clear your queue.
Best regards,
Hugh Henderson
Message 13 of 30
osa065
Hello, I also have this problem with non running simulations. Could you please help me out. Much appreciated! Could i also ask the reason for this
Message 14 of 30
henderh
in reply to: osa065
Hi @osa065,
We've cleared your queue. Please let us know if you're still having issues.
Our apologies for the late response.
Hugh Henderson
Message 15 of 30
osa065
Hello i am still having the same problems. It wont go past this for a very simple simulations
Message 16 of 30
henderh
in reply to: osa065
Hi @osa065,
Could you try again now? Your queue has been re-cleared.
Best regards,
Hugh Henderson
Message 17 of 30
osa065
Still not working unfortunately
Message 18 of 30
henderh
in reply to: osa065
Hi @osa065,
Could you try again? Your queue should be cleared. Please let us know if you're able to solve now.
Thank you for your patience,
Hugh Henderson
Message 19 of 30
zcem1
Hi, I'm having the same issue. Whenever I try to simulate the solve status just remains at 5 percent and does not proceed further. Please let me know if you can help me in this regard. Attached below is my log files for your reference. Thanks.
Message 20 of 30
henderh
in reply to: zcem1
Thank you for providing the log files @zcem1.
I've forwarded your data to development. There is no further info I can provide at this time.
Hugh Henderson
