I recently have run into the issue where I am entering settings for a CNC op and the help screens, pop up and will not go away? I have to either try and close the operations menu and start over or just sit and wait for the help menu to disappear? Anyone else experiencing this issue? Build 2.0.13162 on a regular business license. Thanks, Jgaertner
Sorry I missed this post when you made it.
Is this still happening?
Yes, the screens pop up and will not go away? Also experiencing issues with the web site. It loads as old fashion text only with hyperlinks? then if you click on something, it loads properly. I don't use Fusion every day so no idea what's going on? I have a subscription for my business and bought a Win 10 machine for use with Fusion only recently.
These issues are not related in any way, other than if it's a problem on your computer.
First, since it's a hardware problem, you must shut down all applications and restart your computer.
Are you still seeing stuck tool tips and strange default fonts in the web page?
It might help for you to provide your graphics diagnostic information, found on the Help menu, under support and diagnostics. The information can be copied and pasted from the dialog.
