Fusion 360 Problems
Unfortunately, someone has decided to block another topic about fusion360 cpu issues. Unfortunately, there is still no solution for the high CPU usage of Autodesk analytics client service at fusion360.
@tribeofhill wrote:What is this "AcCoreConsole.exe" process, which appears to be located in an autodesk distribution folder, that is using a significant amount of CPU on my system even when fusion 360 is not running?
I also noticed when looking in task manager that fusion 360 opens a lot of sub processes. For me mainly the process: Autodesk Analytics client service uses a lot of CPU while I don't even use fusion360. Here you can see all of Fusion360's sup processes:
These many sub-processes can also be a cause of many random crashes and bugs. For example, if you search for "Protein engine server" on this forum you will get the following post for example: https://forums.autodesk.com/t5/fusion-360-support/protein-engine-server-stopped-working/td-p/7791254
See: https://forums.autodesk.com/t5/fusion-360-support/fusion-360-sucks/td-p/9680500/page/5
