I would like the parameters window to be NON-MODAL (remain open).
This would provide a more dynamic design environment. Currently I have to open and close the parameters window many times while sketching and modeling which breaks workflow and concentration.
For example, while sketching I realize that a dimension should be driven by a parameter I have to stop, close the sketch, open the parameters window, create the parameter, close the parameters window, then reopen the sketch and apply the parameter to the dimension.
If the parameters window to remain open (perhaps on an adjacent monitor) I could simply click over, create the parameter, then click back into the sketch relatively interrupted.
Thank you for your kind consideration to this design issue.
IMHO this is one of the biggest annoyances with the UI. Its frustrating and eats up time and you often lose momentum.
