Fusion Support
Arrange Function Crashing - Mac
1 REPLY 1
richardherberth
75 Views, 1 Reply
System: MacBook Pro M2 (Pro), 16GB. Formerly MBP i7 32GB, same problem.
Objective: Use arrange function for ~ 30 components to minimise material for laser cutting.
Problem: Fusion hangs, the little rainbow wheel spins and stops repeatedly, and Fusion never recovers. => Force Quit. Error reported a few times to Autodesk.
Trigger: adding my components into the Arrange. I can usually add several of my components, there is no clear max, there is plenty of room in the Envelopes. I have tried: all sketches full constrained; simplified designs, replacing copied components with unique sketch derived components, holes all based on sketch points. I have rebuilt my designs from scratch, but the problem always recurs.
1 REPLY 1
Last night's update seems to have fixed this, after weeks of issues!
