I recently tried to open fusion 360 and it would not respond. Below are the solutions that I have tried:
If you have any more solutions that might help, please let me know. Here is a picture of what Fusion 360 looks like when it begins to crash. My system should be able to handle Fusion 360 and have run it without trouble before.
Do you have 2 graphics card installed? If it is, please disable one from Device manager, launch fusion 360, and then enable back again.
Besides the things you tried, please try this:
Troubleshoot network connectivity issues:
Manually Reinstall or Update Fusion 360
Note: This solution may be helpful when the automatic update is not possible.
Windows account issues:
Check for multiple instances of Fusion 360
@wilsonpetersen111 @Can you please go to the service utility and run the system info and attach the diagnostic files?
also in the windows time and date , can you check if the system has automatic time turned on and if it is not, turn it on to see if that helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
