For some reason, when I try to load up Fusion 360, I'm just stuck on the loading screen. It's taken 10+ minutes and still has not loaded. Is this a regular occurrence?
Hi.
Thank you for posting. It is a common issue and have some simple solutions. First, I like to suggest you some steps and let me know what happens.
I've found this solution from this article:
Still having the same problem, not loading. I also tried re-installing Fusion and restarting the computer, with no luck.
