Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 not loading when I launch it.
2 REPLIES 2
376 Views, 2 Replies
For some reason, when I try to load up Fusion 360, I'm just stuck on the loading screen. It's taken 10+ minutes and still has not loaded. Is this a regular occurrence?
2 REPLIES 2
MoshiurRashid
Hi.
Thank you for posting. It is a common issue and have some simple solutions. First, I like to suggest you some steps and let me know what happens.
  1. Right-click on the Fusion 360 Icon
  2. Go to Properties
  3. Go to the Compatibility Tab
  4. Enable Run this program as Administrator
  5. Apply and close
  6. Re-test.
I've found this solution from this article:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
in reply to: MoshiurRashid
Still having the same problem, not loading. I also tried re-installing Fusion and restarting the computer, with no luck.
