Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
fusion 360 got stuck for over two months now and i cant open previous projects
22 REPLIES 22
Message 1 of 23
o01157835462
1113 Views, 22 Replies
for over two months now i can't export project files both in the desktop app and in the website also it's always saying two jobs remaining whenever i try to close it also when i try to open a specific project it says " can't open latest version " and then open nothing  and i couldn't export to any file type other than f3d and stl now every thing happen to be broken .
Tags (1)
Labels (1)
22 REPLIES 22
Message 2 of 23
@o01157835462 Its possible that a network issue somewhere caused these files to not upload to the cloud.
1. Do you work on multiple machines?
2. If on this machine that you are seeing this error if you go to Help- support and diagnostics - Fusion service utility
3. Run the Reset Fusion
This should clear the queue and hopefully also resolve the issue for you.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 23
i'm working on a single machine and tried every thing possible from resetting to uninstalling and re installing, fixing and  updating still the same problem and nothing changes apart from can't open any previous projects now
Message 4 of 23
@o01157835462
1. Can you go into service utility and run the Gather system info - it will generate two zip files. You can attach diagnostics files.zip
2. Also, would it be possible to invite me into a project where you are having this issue? raj.kumar.ilanchelian@autoesk.com
Autodesk Fusion
Join Fusion Insider
Message 5 of 23
sure , here's the files and i tried to invite you but it won't allow me the invite button is deactivated as shown in the photo
Message 6 of 23
@o01157835462 Are you the admin of this project or are you part of someone else's project?
Autodesk Fusion
Join Fusion Insider
Message 7 of 23
i'm the only member and i think i'm the admin
Message 8 of 23
@o01157835462
I do see the bolo errors in the logs:
E .11772 Design not yet available - "mobile v16" is currently unavailable to download.<br>You saved the design, but your upload may not have finished.<br>If you saved the design from a different computer, the version you saved will finish uploading when you open Fusion 360 and connect to the internet on that computer. - Click here to view error message.
Couple of things to try out here since this could be a network issue:
Please note that the below workflow could lead to a loss of the latest version but could help move forward.
0. Logout of Fusion and close
1. Go to C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\Folder starting with U************
2. Copy this folder to a different location and now delete this folder
3. Login to Fusion again
4. Go to the design that you are trying to open and promote the previous version as the current version
5. from this point on you should be able to make edits and changes and save them
The other option is to see if you can connect to a different network (like a mobile hotspot etc)
1. Logout of Fusion and close
2. Change network
3. Login again
Is it working now?
Autodesk Fusion
Join Fusion Insider
Message 9 of 23
@o01157835462 It seems like you are in another hub where you have Editor access. If you are an admin it will call out as Project admin. Are you having a student license and you are being invited into a team hub ?
Autodesk Fusion
Join Fusion Insider
Message 10 of 23
tried the first method nothing changed and i'm on the personal version
Message 11 of 23
@o01157835462
After trying out the first method:
1. now when you close Fusion you should not get the message that there are 2 jobs remains. Can you confirm that?
2. Now when you open the previous version and save it (yes you will lose the new changes) but it should help you move forward with newer saves. Can you confirm?
Autodesk Fusion
Join Fusion Insider
Message 12 of 23
yes for the first question it closes without mentioning any jobs remaining and for the second question when i click open previous nothing opens it refreshes fusion and do nothing
Message 13 of 23
@o01157835462
1. Go to the data panel and expand on the design and open the previous version from there
2. Open the previous version
3. Now go to File - save as latest
This should now upload and set this as the latest version. Do a new edit/save and it should upload. Screenshot 2023-10-18 at 1.52.24 PM.pngScreenshot 2023-10-18 at 1.52.50 PM.png
Autodesk Fusion
Join Fusion Insider
Message 14 of 23
i think my interface is  different from the one you showing and offers a limited options too , also i  invited you to the hub
Message 15 of 23
@o01157835462 Expand the V16 that you see. If this is the version that is not opening, open V15. and dod the File - save as latest
Autodesk Fusion
Join Fusion Insider
Message 16 of 23
yes it opens at version 13 and i saved it as the latest version but seems it'll gonna stuck again since it's not really uploading
Message 17 of 23
@o01157835462 @Looking at the image looks like V14 was already impacted. V13 shows the image leading me to believe this one was successfully uploaded.
couple of thing to do.
1. Open v13 and do the same and see if now that gives you access to the project. If upload is still blocked it is possible to connect to a different network to see if it could be a network issue?
often times restarting the router could be a solution as well but first try the v13 ad the first step.
Before doing this workflow for V13, remove the folder I had called out earlier. This will make sure the new version that was not uploading is deleted.
Autodesk Fusion
Join Fusion Insider
Message 18 of 23
@o01157835462 @Also another test to narrow this down is delete the folder I called out earlier. Now open a new design and draw a simple box. Save it and see if this is uploading.
Autodesk Fusion
Join Fusion Insider
Message 19 of 23
removed the folder and restarted the router and closed it re opened the app and it's loading and not even clickable for the creating a simple box test i did and got uploaded without any problems
Message 20 of 23
@o01157835462 so new files are uploading with out any issues.  It’s this one file that is causing problems right?
Autodesk Fusion
Join Fusion Insider
