Fusion Support
Fusion 360 freezes at launch
1 REPLY 1
j.han97
134 Views, 1 Reply
Hi all,
I have encountered a problem since yesterday: As indicated in title, Fusion 360 froze at launch. Here is a screenshot to demonstrate the state of Fusion 360:
Sometimes it was able to go further (I guess) to show the data panel on the left and froze there.
Things I have done before this problem (testing API in command window within Fusion 360):
1. Switch Fusion 360 offline
Application.isOffLine = True
2. Check current user
Application.currentUser
Step 2 returns nothing to me and Fusion 360 started to freeze. Since then, I was unable to open Fusion 360.
Things I have done to (try to) repair Fusion 360:
1. Clean uninstall and reinstall
2. Uninstall and delete every Autodesk-related file, then reinstall
3. Re-install and delete two xml files:
      C:\Users\%username%\AppData\Local\Autodesk\Web Services\LoginState.xml
      C:\Users\%username%\AppData\Roaming\Autodesk\Neutron Platform\Options\NMachineSpecificOptions.xml
4. Used the Fusion 360 troubleshooter here (https://autode.sk/32r43MD)
In step 1~3, I have restarted the computer multiple times (usually uninstall -> Restart -> Re-install).
Things I have not done:
1. Check the internet connection. Since I was able to use Fusion 360 without any problem before yesterday, internet connection should be fine.
2. Disable antivirus. I am not allowed to modify the antivirus settings, and I thought it should not be a problem since there has been no change in antivirus for a long time.
Can anyone help solve my problem? Thanks a lot in advance!
1 REPLY 1
j.han97
in reply to: j.han97
Currently I have no idea what should I try so I just repetitively launch (and kill) Fusion 360. Something very interesting is, occasionally Fusion 360 was able to complete its launch (Maybe 1 out of 10 launches).
However this does not solved the problem: After a successful launch, I quitted Fusion 360 and re-opened it: and it froze again!
