Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
FUSION 360 Drop Down Menu
4 REPLIES 4
804 Views, 4 Replies
Is there a way to change the display size of the menus, or split them into smaller groups?  When there is a very long description or many options to choose from, my display doesn't show all of the descriptions or available features.  I've attached a shot of the CAM section for "Drilling Cycle Types" where the first 3 descriptions are cut off.  I already have my screen resolution set to the highest res available and I can't scroll up or down on the description window.  Any suggestions?drop down menu.jpg
Tags (2)
4 REPLIES 4
innovatenate
innovatenate
Autodesk Support
Autodesk Support
It looks like that tool tip might just be a bit too large. So I can properly report this internally, can you help me out with a few questions?
What is the screen resolution you're currently running on?
Can you upload a copy of your dxdiag report? It will help me to see what text scaling settings you're using as well.
  1. Launch dxdiag.exe on your Windows computer
  2. Select Save All Information
  3. Please reply with the resulting *.TXT file attached
Thanks in advance for showing this to us!
Nathan Chandler
Principal Specialist
Nathan Chandler
in reply to: innovatenate
Hey Nathan,
Thanks for getting back to me so quickly.
 1280x800
Hey Nathan,
 1280x800
TrippyLighting
TrippyLighting
For CAD and 3D3D modeling wok you should consider at least 1920 x 1018 resolution.
If your computer cannot display that higher screen resolution then chances are it will be running out of breath rather quickly when working with Fusion 360.
in reply to: TrippyLighting
Working on a Macbook Pro provided by the school, for the most part it handles Fusion very well.  Only if I have a ton of Chrome tabs opened up will it start to bog down, but that's because stupid Google is hogging all of the ram.
