Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 does not run on Ryzen Hackintosh since last update.
68 REPLIES 68
Message 1 of 69
GroovyDrifter
8610 Views, 68 Replies
I know, I know, it is not supposed to run there, that same computer also boots Windows and there it runs fine, I just have to reboot the computer and problem solved, just wanted to let you know in case there is a simple way to fix it without degrading performance, or something I can do in my computer to make it run. I'm setting up NAS servers in FreeBSD and it's just easier in MacOS, my real MacPro is just too heavy to carry everywere.
68 REPLIES 68
Message 61 of 69
roger
in reply to: GroovyDrifter
Ok, interesting. Just got the latest Fusion 360 update and did not need to re-run my fix. Not sure why.
Fusion 360 2.0.16486 x86_64 [Native]
macOS 13.4 (22F66) on MacPro7,1
System Integrity Protection status: enabled.
What I did: (xxxxxxxxxx = my personal Apple Developer team id, I don't have an active paid account)
I have not experimented with what files are relevant and what not, I just signed all executables. I also did not try if ad-hoc signing works. (replacing the "xxxxxxxxxx" with just a "-")
cd ~/Library/Application\ Support/Autodesk/webdeploy/production/Autodesk\ Fusion\ 360.app/Contents/Frameworks/AIRMAX/
amdfriend --in-place  libtbb.dylib
amdfriend --in-place  libtbbmalloc.dylib
codesign --force -s xxxxxxxxxx Ad*
codesign --force -s xxxxxxxxxx EnGen
codesign --force -s xxxxxxxxxx adex*
codesign --force -s xxxxxxxxxx gent*
codesign --force -s xxxxxxxxxx lib*
codesign --force -s xxxxxxxxxx lvvfs
codesign --force -s xxxxxxxxxx rtslc
Man page for codesign: man codesign
Message 62 of 69
aaron.zschau
in reply to: roger
Thanks, I'll give that a try once I figure out how to re-enable SIP, backing out the changes I made to disable it didn't seem to work.
Message 63 of 69
brunosaraivaf
in reply to: tomnicYXQYQ
Thank you for that,
Your files saved me the frustration of days of failed attempts to run Fusion 360:
Specs:
HW: Ryzen 7 5800X - 32G RAM - RX6600M
OS: Sonoma 14.2.1 / iMac Pro 2017
Fusion V: 2.0.18441 x86_64
Message 64 of 69
roger
Well again some changes. Latest Fusion update only requires:
But there are some window issues; Data Panel is now empty and opening the extensions window also glitches.
I see these messages in console:
QPainter::begin: Paint device returned engine == 0, type: 1
MAG.Default: [Idle Status] Report Idle(Idle or Not):  false
Message 65 of 69
tomnicYXQYQ
It seems ok to me, do you have a fully metal 2.0 compliant video card? Be sure to also re-codesign the whole app using:
codesign --force --deep --sign - ~/Library/Application\ Support/Autodesk/webdeploy/production/Autodesk\ Fusion\ 360.app
Message 66 of 69
roger
Hi Tomnic,
My Data Panel remains empty, completely removed fusion 360 and did a fresh install, still the same.
I run Sonoma 14.0 (which may be causing it)
I have a AMD Radeon RX 6900 XT 16 GB which is reported as supporting Metal 3.
AMD Radeon RX 6900 XT:
  Chipset Model:	AMD Radeon RX 6900 XT
  Type:	GPU
  Bus:	PCIe
  Slot:	Slot-1
  PCIe Lane Width:	x16
  VRAM (Total):	16 GB
  Vendor:	AMD (0x1002)
  Device ID:	0x73bf
  Revision ID:	0x00c0
  ROM Revision:	113-D4120100-100
  Metal Support:	Metal 3
Message 67 of 69
roger
Hi Tomnic,
I have RX 6900 XT 16 GB which is reported as Metal 3 compatible. I run Sonoma 14.0 which might be an issue...
My Data panel remains empty and when I code sign the full app I cannot login anymore.
Regards, Roger.
Message 68 of 69
tomnicYXQYQ
in reply to: roger
Try to update to 14.4 which is the version I use now, same GPU here!!! I hope you're using an updated WhateverGreen.kext and Lilu.kext
Message 69 of 69
roger
14.4 fixed the Data Panel issue!
Thanks!
