I want to create a cabinet with panels in a groove. I am trying to create a rectangle to extrude into a panel to fit into an existing groove. I want to use the corners of the groove cross section as two point defining the rectangle sketch. The plan was to extrude that rectangle down the length of the groove. I define the plane of the rectangle at the end of the groove cross section but instead of snapping to the vertices of the rectangular grove, the cursor remains free floating. I even tried creating construction points at the vertices, but they are not accessible when drawing in the sketch mode.
I could probably use the measurements of the grooves and the separation between the two grooved boards, but the idea is to use the existing components as reference points so I don't have to recalculate every thing.
Thanks!
I don't know if the attached project file will show the issue.
